JustAnotherProblem
Thread starter- Joined
- May 10, 2017
- 10
1973 135hp not sucking fuel. I have gone through and cleaned all fuel lines, cleaned the carbs, have cylinder compression, 100,100,100,70. I know that it is not the best to have one. cylinder that far off from the others, but not sure if that is the cause of my problem. This motor has been nothing from problems from day one. I have completely rebuilt the lower unit putting in new gears and everything, I didn't have spark on any cylinders, but think I have solved that problem, replaced all the ignition coils and increased cranking amps on my battery, now I can get a spark on all plugs while plugs are in the case. The major problem now is no fuel to any cylinder at all. I know there is no fuel in any cylinder because I have completely dried the spark plugs reinserted cranked and cranked and pull the plugs, still dry. I can stare down the carb throats and there is nothing comeing out of the "nozzle" if you will. There is fuel in the carb bowls. Any advice please.
