1972 Sportster RPM's
funchucky
Hi.<br />I'm trying to help my Dad out.<br />He recently bought a '72 25hp Sportster (25202R-E03189) .... and he's got problems.<br />It starts well, idles well, and runs well at low speed.<br />When he tries to accelerate, though, the motor spins, the prop spins (he explains it as lots of bubbles and activity in the water back there), but the boat doesn't go anywhere.<br />Now, the boat isn't that heavy (he took off an 18hp Merc that made the boat plane pretty easily), so the 25hp Evinrude should do fine.<br /><br />He describes the prop as being "tiny, much smaller than on the Merc."<br /><br />I'm 3000 miles away, so my advice is limited, but no doubt you can all help more than I can.<br /><br />Here are my guesses - <br />1. A problem with motor height / shaft length - I'll have him take a look at that, to confirm that the Cav plate is below the bottom of the boat.<br />2. A problem of Ventilation / cavitation due to an undersized / underpitched prop.<br />3. A slipping hub (if that's possible with the prop he has)<br /><br />Before he goes out and buys a new prop tomorrow - am I on the right track?<br />Also- what's the proper RPM range for this engine? <br />Thanks so much!!!!
rickdb1boat
Re: 1972 Sportster RPM's
funchucky <br /><br />I'm going with door number 3, if # 1 has been ruled out. <br /><br />
Chinewalker
Those 25hp/22-cube motors like to rev to make power, so if you can get it in the 5500 RPM neighborhood, you're doing well. <br /><br />I'm betting on the slipping prop hub, too, assuming the motor is running on both cylinders and it's deep enough in the water... Lots of motors can run on one cylinder and "sound" okay to the uninitiated.<br /><br />- Scott
