1972 searay with a 165 mercuriser
seancota1992
Hi everyone im looking to buy a boat with inboard it's the straight six Merc engine guy said it ran last year when he bought it and brought it home and when he put the muffs on it and when to start it it would crank no start ran battery dead doing it now the oil is milky but smells like fuel any suggestions on this before I jump into buying it thanks
alldodge
The block is probably cracked, and fuel pump is leaking, just walk away
Ayuh,..... Welcome Aboard,...... Keep Lookin',... There's Much Better deals out there,... Try to buy into the '80s or later,....
seancota1992
Is it possible to convert a straight six Chevy motor into a marine engine can get motor for 50 and the boat and trailer for 300
alldodge
I doubt it because:
Can you get a 165 truck motor, swap parts, gaskets, core plugs for $50 or less
As far as the boat and trailer, probably for $300, but it probably needs some work
seancota1992
It does need some work but it's complete and I can get the complete engine for 50 and then I would have to swap stuff over
998cc
The engine blocks are different. The Chevy motor most likely is missing the mounting tabs for the front marine motor mount. It can be converted, but it will take some work and ingenuity. Do a search in iboats forums for this fix. The law of Caveat Emptor tells me that a $50.00 motor likely needs work--perhaps a rebuild.
alldodge
I've never been the sharpest tool in the shed, but I have to ask, what front motor mount on a inline 6?
Wait I take it back there is a front motor mount, told you I wasn't the sharpest.
That said the GM block is a GM block, the mounting holes for the motor should be there
seancota1992
Planned on a rebuild but also the oil is milky but it smells of raw fuel he said when he got it it ran and then the next day after buying it it wouldn't start would a flooded crank case with gas make the oil milky after sitting for over a year??
seancota1992
Update it's definitely fuel in the oil they cranked it so much to try to start it and come to find out the rotor button is broken so replaced that but the fuel pump isn't pumping can I bypass the mechanical and install a electric pump with a regulator
CamaroMan
a marine elec pump yes, for a test anything will work, as long as its a 3-4psi pump..
My 74 searay had milky oil, just not enough rtv in the intake corners.. re sealed mine and been running fine ever since. Gas in crank case - hmmm, leaking past worn rings.
buy a android optical camera off fleabay for 10 bucks, stick it down plug holes.
Rent a compression gauge from autozone - not sure if you can pressure test a ford block without blocking off the elbows.. i seem to have been told GM elbows seal the water off, where ford have weep holes that slowly enter the exhaust pipes (which is why a pressure test will fail).. but u need to ask some experts here about that.
I had a motorbike sit for 1 yr with fuel in on and crank filled with gas. drained / refilled - been going like a champ for 5 yrs.
best u can do is try get it running (well). flush cank case, pour in cheap oil and see what happens after a few hot runs.
seancota1992
I have to replace the bellows there torn and my power trim won't work so can't get it to go up and down im tryng to find what bellows to get it's a 1972 sea ray with a mercruiser 165 all the outdrive says is sterndrive
Bt Doctur
Not quite, the mounting ears were used a very few GM inline 6 motors look to the right of the timing cover. If you see to threaded holes that motor will work if no threaded holes it wont accept a front motor mount
CamaroMan
I think all the outdrives 60s-70s-80s use the same bellows, perhaps more models. Only slight difference wd be the gasket for the later alpha would have an extra hole for the oil reservoir -
Search for mr, alpha 1, bellows kit and ull find plenty! the kits usually come with more parts for the different models (which helps). You can also just get the bellows and water hose (its a double wall type weave reinforced - not the flexible auto stuff) and use your old clamps etc.
Do a shift cable job while ur there and replace the intermediate shift seal and the seal on the upper housing drive shaft seal..
Check ujoints too and bearing.. ANY sign of rumbling in the (or any bearing) is bad.
Bt Doctur
The main difference in the main bellow is the addition of a small ridge in the rubber .Early housing do not have this and use the bellow without the ridge
KJM
Sounds like you are buying some else's mistake......I wouldn't walk away, I'd run!
seancota1992
Update installed plugs and new rotor and used a spray bottle and she's alive no knocks no ticks runs like a sewing machine
