1972 searay steering control replacement
seancota1992
Steering cables stuck
1972 searay 18ft MerCrusier 165 pre alpha need steering fixed some one tryed to weld the tube but it broke and it seems they welded the cable to the cable tube because the steering wheel won't turn where can I find the parts to fix it
alldodge
Need to start with what helm you have installed. Being a 1972 the best bet would be to replace the helm and cable. Seastar or Uflex makes a wide verity
alldodge
How do I find out what I need?
Have to take things apart, but if your going to replace all of it, I would call Seastar and ask them what they would recommend. So far as the length of cable, remove it and measure how long it is
seancota1992
I need to replace my steering control cable and the tube on the end can't upload a pic but have one to go by if u msg me I will send it to u someone welded the cable to the tube so the wheel won't move anymore
