1972 Mercury 500 50 HP
64Amphicar
Hello all, I am working on a 1972 Mercury 500 50 HP outboard. I am trying to get it running, but not been having any luck with getting an spark. I do not see a coil on it any where. Also no wiring to the ignition driver. Any one have any advise on these engines? The serial # is 3096872 or 3096372 not sure if it an 8 or a 3 The grey wire attached to the side is spliced to the orange wire from the wiring harness
64Amphicar
Upon looking further I do not see a switch box on this motor either. At this point I am not sure if it a 1972 engine?? Also does any one know the wiring positions for the key switch?
GA_Boater
Let's get the right motor first. Your serial number is for 1971, but you have a 4D-5 magneto. A '71 has an ignition driver and switch box and no magneto.
You may have an older powerhead. Is there a serial number stamped below the timing pulley?
Honorary Supreme Mariner
---The drive belt is not broken ?----Follow the wire from the cap to the coil.----It may not look like a traditional coil.-----Then again perhaps the distributor was replaced with a magneto from an earlier motor and the coil is inside.----Or the block was replaced.-----Bring it over or post some pictures of this fine machine.----If it is the magneto then you simply remove the bottom part.( 3/8" wrench and 4 screws ) to do that.-----Then carefully find the breaker points and clean them.-----Set them at 0.010".----Work carefully as those parts are expensive.
64Amphicar
That # is 2106695 I was given this engine and was told it was a 1972, I do not about the year, just want to get it running.
GA_Boater
SN 2106695 falls in the 1967 range;
The wiring diagram,which includes the key switch;
Racerone's advice about expensive parts is all too correct. A Merc magneto ignition is simple and reliable, but parts are harder and harder to find with matching prices.
64Amphicar
I am not sure what I have, there is no coil or switch box on this engine. It was given to me and all I know is from what I have been finding online. The only wire to the distributor/magneto/ignition driver is the grey one that has been spliced to an orange one coming from the wiring harness. Any and all advise is greatly appreciated.
The coil is INSIDE that magneto assembly !!----An elegantly simple / reliable device it is.-----You have to learn how to work on this machine as you will be shocked at the cost of work at a shop !!
64Amphicar
That looks like what I have, now I need to figure out the wiring at the ignition switch. The diagram above shows A B C D E F my ignition switch has M B M C A I and wiring harness has RED, YELLOW,WHITE,GREY, BLACK, BROWN and ORANGE wires. All have been disconnected so I am not sure which wire goes where. Thank again for all the information.
64Amphicar
Post a picture of your remote control.
The ignition switch is mounted on the dash, not in the remote control. Looks like the throttle/shifter lever has been replaced with an after market one. It is dark here, but I can get some pictures tomorrow.
Remove the ONE wire ( gray ) from the magneto.----Now test for spark.----Do not apply 12 volts to this magneto.----Any smoke resulting from that will be expensive.----The magneto does not need 12 volts to make spark.
64Amphicar
Don't put words in my mouth. My words are asking for picture, not all that stuff about wiring.
Some how I think you have the wrong control box / ignition switch for what is installed on your motor now !!----The magneto does NOT need 12 volts to make spark.----Remove the one wire on the magneto and test for spark.----Not hard to do.-----You might as well consider removing the bottom half of this magneto ( 4 screws and a 3/8" wrench ) and easy job..----Need to clean and set breaker points at 0.010" .----No need to worry about timing. ----Most shops won't work on these simple magnetos anymore.----Best to learn this yourself.-----You will be saving lots of beer tokens that way.
64Amphicar
I was given this pontoon with this engine mounted on it. It had an Evinrude 40hp on it before. The pontoon is a 1995 Tracker. He had replaced all the wiring harnesses with Mercury wiring harnesses for this engine. The ignition switch is also aftermarket. I have the Red(Battery) wire attached to the B terminal, Orange (Magneto)to the I Terminal, Yellow( Starter Solenoid) to the Y terminal and the Black (ground) to M Terminal. I now have power to the Orange wire (Magneto) that stays on when the key is in the ON Position. I believe the Gray and White are for the choke and Brown for the Tach. Should I now attach the Orange wire to the Magneto and see what happens?
I have clearly stated that the MAGNETO does not need 12 volts in order to make spark.------Post a video of possible smoking if you continue with your approach.
64Amphicar
I realize that, that is why I am asking these questions about the wiring at the ignition switch. By putting the Orange wire (Magneto) on the I Terminal at the ignition switch, I have power to the magneto wire when the ignition switch is in the on position. Is this right??
No it is not ------The magneto does not need 12 volts.----The wire going to the magneto is put to ground to stop the engine.----That same circuit is OPEN in order for this magic magneto to produce spark !!-----Put that magneto on your work bench with not a single wire attached.-----Hook up a proper spark tester.----Spin it by hand.-----You would see spark like a small electrical storm.
64Amphicar
This is probably why the guy gave it to me, so I need to put that Orange wire on the Ground terminal at the ignition switch??
