TheguyDirk
Thread starter- Joined
- Jun 24, 2020
- 23
1972 Sea ray with a ford 302/holley 2bbl carb. I recently had a tsp of gas in the sight glass of the fuel pump so I replaced the pump. After that it refused to start until I disconnected the boat tank and plumbed a line direct into a gas can. Started fairly easily from there and idled for 5min+ so I shut it down and replumbed the main boat tank. It started less easily but started and idled up to temp. Sounded sort of rough at idle and had a hard time maintaining 750-800rpm. Sounds okayer at 1000rpm. A week later I am attempting to start the boat again and it will crank but will not cough or try to start. If i give it gas directly through the butterfly choke itll kick and try to run. Not sure if im having an issue with the gas in the lines making its way back to the tank or if im having issues with my carb.
Previously with the fuel lines disconnected at the pump it could not build enough head pressure in the long run, or pulling air, to run. The jerry can length run is much shorter and can prime easier. Is there a check valve somewhere on these old tanks? Mine is in the nose of the boat and accessible not under the floor. I am able to hear air returning to the tank if I blow backwards into the line.
Im thinking it's pulling air from a cracked old line or something since if everything is sealed the fuel pump should retain vacuum on the line side. right?
