1972 Merc 140 I/O Problem
fragamb
I have had a problem of getting water in my oil. I ran all of last year changing the oil everytime I went out. My questions are
1. How do I find the source? Should I pull the head? Would any other gaskets like the riser or the exhaust cause this? I know it could be a cracked block if so how do I check for that? One thing to mention is the exhuast bellows is in 2 pieces would that cause this problem?
2. At this point do you think the engine is shot? It still runs pretty good? Should I pull the engine and have it rebuilt? How much does it normally cost if I pull the block and bring it some where.
Any advise would be appreciated. Wondering if I should keep running it till it dies or invest some money into it?
Haut Medoc
Re: 1972 Merc 140 I/O Problem
The most common reason for water in the oil is a bad exhaust manifold, riser or the joint between them....
Bad exhaust bellows will not cause it....
You can pressure test your block & manifolds to check for leaks....
I would do a compression test to see the engine's overall condition....;)
Do some testing....
A compression test & a vacuum test will tell you alot about the engine's condition....
Welcome to iboats, btw.....:)
Ayuh,........
Block off some hoses,+ Pressure Test the cooling system with 10/ 12psi of Air,+ Listen........
You'll Hear where it's coming from.......
My 1st Guess would be the Inside Wall, just opposite of the block drain on the outside.......
That's a common Freeze Damage spot......
The Exhaust Bellows on the outdrive is Wet on both sides,.... Kinda irrevelant.....
Good Luck,+ Welcome Aboard.......
