1972 johnson shearing a flywheel key
changetires
sheared a flywheel key on 1972 Johnson 40 hp. Is there anything special you have to do with the timing or top dead center when reinstalling the flywheel and key?
tks
jbjennings
Re: 1972 johnson shearing a flywheel key
THe flywheel key is what takes care of the timing, so nothing special needs to be done with TDC or otherwise. Clean your crank taper of all all grease and oil, install the key and flywheel, and most importantly----torque it to specs. If you don't use an OEM key and don't torque it properly, it will reshear and eventually ruin the crank.
JBJ
wilde1j
No, but the flywheel bore and crank end must be clean and dry, plus the nut MUST be torqued to the correct value. You only get a few tries, before the flywheel and crank become junk. The reason for shearing is almost always the nut wasn't torqued. BTW, don't use a hardware store key.
Faztbullet
Do all the above but I go a step further and lap the crank to flywheel.....
wilde1j
Lapping is fine, if you have enough metal left.
fishfeatures
ok..... I'll ask.....
What is lapping ?????
F_R
Honorary Supreme Mariner
A person that should know, says that the 40hp flywheel should not be lapped. He grew up in the Evinrude factory.
tx1961whaler
Torque it to 105 ft-lbs, or it will shear again.....
JDusza
Lapping is an operation in which two surfaces are rubbed together with an abrasive between them, by hand movement or by way of a machine.
J
changetires
Thanks for the reply and answers. I have new BRP keys ordered and will be here shortly. Thanks again for all the info.
1946Zephyr
Yep, those are the shorter keys, since the points cam is molded into the crank. The old ones (1961 and earlier) had the longer key.
Dankeeton
I have a 1958 35 hp evinrude. Anyone know where I can order the correct key (longer one)?
Daviet
Dankeeton, you should start your own post so that you don't get lost mixed in with someone elses.
I think the part number for your crankshaft key is 302602, check with your local dealer, they might have them in stock. Or you can order on-line, but the freight will far exceed the price of the part.
