The problem first occurred when I accidentally left the key on over night some time ago. The motor would not run due to no spark after that. I recently started toying with it again only to find that the motor will not crank over at all when turning the key to start! (Yes I've went through all the battery terminals and connections,, that's not my problem) so I jumped the starter right to the battery by running a hot lead from the positive side of the battery to the starter and it turned right over with good spark!! But still couldn't get it to turn over from the key, so I decided to rig in a second solenoid to just turn the motor over to run! But no I have no spark again. Is the problem stemming from the "Power Pulse" pack that I can't seem to find ANYWHERE. (Model number 6CB2001). Can anyone help me?! PLEASE!!! Or is something wrong in the controls killing the ignition??
