I'm trying to remove the lower unit on my 50hp Johnson. I have removed all the bolts on the bottom of the lower unit, but will not drop. I have been reading some info here on the forum that says there is usually a bolt or pin under the bottum carburator but there is nothing on this moter. Also I have heard you need to rmove the shifting linkage although I don't see how that would work on this moter since it is not mechanical. Please help.
Thanks
Dave
Thanks
Dave
