1972 johnson 9.5 starts but won't keep running
A.G.A. clue
I have a 72 johnson 9.5 that I just got running.it hadn't been run for at least 15 years.I cleaned it up and replaced the fuel pump now it starts 1st pull every time. The problem is it only runs a few second and dies. Is there an adjustment on the fuel pump? Any other ideas?
Any help would be greatly appreciated.
Thanks
Joe Reeves
Re: 1972 johnson 9.5 starts but won't keep running
Clean and rebuild the carburetor using a complete carburetor kit, available at your dealership, NAPA, Sierra, etc. Use Champion J6C spark plugs, gapped at .030.
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note 1: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
Note 2: If the engine should be a three (3) cylinder engine with three (3) carburetors, start the adjustment sequence with the center carburetor.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
