1972 Johnson 85hp Hydroelectric. - Shift problem
Micheals2018
Okay so here I am again.
I got the boat running and wired properly now and took it to the lake last weekend. I was able to have some fun for 10 minutes before I put it back in neutral and it seemed to bog down and die. I tried firing it back up to no avail, it wouldn't switch into neutral to start up. I waited 10 minutes and tilted the motor and got it to fire up, I quickly put it in forward and it gave a light clunk and started going. I then put it back in neutral and it bogged down and shut off. After that I couldn't get it started again.
after bringing it back home and ohm testing the shift solenoids (before the water I was getting 5.7ohm on both) when I tested them, I was getting a wild reading on both. I took the solenoids out and noticed that the wires are a bit frayed and exposed (closest to the rubber seal) and that some of the oil is going thru the rubber seal up thru the wiring housing.
so I'm assuming because of the frayed wires, I'm having a voltage leak which is causing the solenoids to not function right? The oil isn't milky.
my question is, how do I fix these frayed wires when they sit in the oil? Getting the wires back in and closing the case seems to twist the wires quite a bit (caused the fray)
Rustywrench
You may need to think about looking at the assembly #383878. Good pictures & assembly sheet on popular bidding site. The lower solenoid is NLA now. Hope that helps. Haven't done one of those in a long time.
