crawdaddy115
Thread starter- Joined
- Aug 1, 2015
- 1
Hi all!
I have a 1961 Starcraft with a 1972 Johnson 65hp outboard motor and an Evinrude Selectric remote control. I have replaced the Forward Reverse Neutral switch and ignition switch. Problem being, I made a bad mistake, I disconnected the components and then discovered there are more than one purples, blues, blacks etc.. I referred to an online wiring diagram but cannot read the details. I did the best I could based on the diagram but, somehow I melted a wire from the directional switch when I started the engine, and now I am not seeing spark - the starter flies up and spins the fly wheel, tons of gas mist comes out of the spark plug ports, but there is no spark. I think I might have 'fried' the power pack. Is there a way to confirm that my wiring is correct and a way to test the power pack? Thanks ahead of time for reading and happy boating!
Chris
Chris
