fstorm08
Thread starter- Joined
- Aug 2, 2010
- 686
Re: 1972 Johnson 50hp 50ESL72C Questions
sounds exactly the same
Have you decided on the tell-tale on yours?
The impeller plate is in pretty good shape on mine but will replace it as I believe one comes with the waterpump kit.
Thanks for the response Hoytfstorm: Hey man, I have the same motor and went through the same thing last season changing the impeller. Believe it or not, I also broke one of those bolts on the water pump too, my bolt actually broke off screwed into the hole. So I have one less bolt for the water pump. I tightened the remaining ones down and then sealed it of with the blue gasket seal stuff. I don't have a tell tale but the water comes out the exhaust ports like it is supposed to do.
No cup, mine looks just like yours.
I don't remember a seal being between the pump and water tube, but I will check my manual and get back to you on that.
Not sure about the exhaust seal, mine probably needed to be changed but I decided to put it off till next season.
I had a lot of unburnt oil/gas mixture coating everything inside mine but that was before I rebuilt carbs and put in new plugs and fuel lines.
