Markerss225
Thread starter- Joined
- Jul 5, 2025
- 7
I’ve picked up a 25hp for my boat and it ran good enough but as I dig into it. It stopped pumping water, it does not like to idle for long either. Cleaned the carb and tested in bucket was doing good. Took it out for a run and ran great out to the lake center shut it off fired right up and road back to shore. Second trip is when it began stall out at idle. But ran good otherwise. Took the carb off cleaned it real well checked and double checked everything set back to factory and fired it up in my bucket to start getting the fine tune and no water was spitting. Checked impeller, housing, plate. Doesn’t make any sense why It wouldn’t pump. Pickup tube is good can push water through up and seams to come out the spit hole in back. Where do I check next? Plan is put the lower unit on and to pull the thermostat off to see how far the water is getting maybe a clog?
