1972 johnson 25hp runs rough
joe priddy
Just purchased this motor. Previous owner tanked it and seemed to run good. Took it out and at about 1/3 throttle rpm's dropped to idle, then catch again and then back off again. What are the possible problems? Thanks
jasper60103
Re: 1972 johnson 25hp runs rough
Compression and a spark test is a good place to start. Congrats on your new motor. Good luck.
mables
Agree with above^^. Does it only do it at 1/3 throttle or does it continue when you go the rest of the way? If no issues are found with compression and spark then the next step is a good ol' carb cleanin.
