Speedingskagit
Thread starter- Joined
- Sep 11, 2018
- 14
So, let me start off by saying, this website, has definetly saved me from royal screw ups. Kudos.
Recently i purchased a 1972 johnson 25 horse outboard. A real beauty. It is a rope start, and has been equipped with an aftermarket electric starter.
When i went to purchase this motor, the owner had it set up in a water barrel to verify that it ran, naturally. He had just replaced the points, and condensers (and gave me the old ones for back ups.) Regardless, we removed the flywheel to verify he did indeed replace them, replaced the flywheel, and proceded with a compression check. Both cylinders ran 120 psi, and afterwards, we started the motor via electric starter. Ran like a absolute dream.
So to save weight in my boat, i figured, well, it is a rope start, no worries, I'll simply pull start it. My shoulder, on the other hand greatly disagreed, but after about 10-12 pulls, it fired right up, and was a dream. After that, one pull starts no problem.
so i am curious, can this be a case of 'look into the carb set up' or 'check the ignition timing'. Im at a loss of where to start.
Or is it a case of i got spoiled after fixing my 73 evinrude 9.5 (thanks to this site) with easy one pull cold starts, and simply need to bring a battery with me?
