1972 Johnson 25 & 20 Lower Unit
oregonducker
Anybody know if the lower units from 1972 Johnson 20 and 25 horse motors are the same? Trying to find parts for my model 25R72 and have found a 20R72 but I don't know if everything is the same. I really just need the gears. Thanks for any info.
Dhadley
Re: 1972 Johnson 25 & 20 Lower Unit
The lowers are the same. The J 20 is the same as the E 18. The 25 has a different crank, piston, cylinder head and carb. The crank and carb can be used on either. Keep the 25 piston and head together. Do not put the 25 head on a motor with the 18/20 piston.<br /><br />Good luck!
