redbrass_ca
Thread starter- Joined
- Dec 31, 2011
- 4
Hi members
I am looking for piston rings sets
I have a question relating piston and piston ring for a fastwin 18 hp (1972) From what I read so far it appears the 18 HP engine was manufactured from the late 50's to the mid seventies. I have tore down the engine and both piston 1 and 2 have cast numbers which is 317564. I have a 1972 exploded diagrams of the outboard and it lists reference number 385338 for the Standard piston and 385349 for the piston ring set. When I look carefully at my pistons it has two ring grooves. They are both different . The top piston groove is tapered and is 2.3 mm wide. The bottom piston groove is 1.62 mm wide and square The Piston is 63.22 mm in diameter . Could anyone help me in locating the proper part numbers? Is there aftermarket rings for these pistons? Any suggestions would be appreciated
Terry
Terry
