BlueGhost93
Thread starter- Joined
- Oct 15, 2013
- 114
Hi everyone. Im new to this forum and have a few questions. I just picked up this 18hp fastwin and it needs a little tlc before I put it on my boat. It fires right up on the first pull. Its missing a prop and the lid latch is missing the piece that the little lock arm grabs to hold it down. So here are my questions.
1) I need a new kill switch/button, prop, hood latch, and that little white plastic piece that hold the fuel mix adjust rod to the motor on the front , where can I find these?
2) Possibly need a new master seal kit for the bottom end? And probably a water pump but the current water pump works just fine.
3) Was told I should re grease or get new bottom end bearing behind where the prop goes?
4) What fuel mix do I need to run?
Oh! one more thing. My prop shaft doesnt seem to have splines???? What kinda prop would I need.... How does it attach... EDIT: After looking some stuff up maybe its a 1971? I cant find a part number on it but its a short shaft 18hp according to the previous owner who said it is a 72... Looks just like this one Evinrude 18 hp twin fastwin
Oh BTW, I have a 14' 1979 Seanymph v hull. Idk what prop to look at or get....
