1972 Evinrude Fisherman 6hp won't start.
Oddball78
Someone gave me this little outboard a few years ago. Always ran great, never had a problem with it, usually starts on the first pull. Perfect for my little 14 foot Jon boat.
I ran it last week and it did fine on the water. Now it will not start. It is acting like it is not getting gas, however when I remove the bottom screw off the carb its full of gas. So I know the gas delivery is not the problem.
The only thing different that happened was I left my boat and engine out in a rainstorm we had last week. I always keep it in the garage but this time I totally forgot to put it up.
I know next to nothing about working on outboards. I'm not sure where to start troubleshooting, I was hoping some of the more experienced among you guys could help with what to troubleshoot first. I can't go fishing with no motor.
RCO
Check for spark- should jump 1/4" or more open air gap. Also check for water in the fuel tank since it did happen after a rain storm.
Oddball78
OK, stupid question, how do I check for spark with no spark tester? And how would I know if there is water in the tank? Or would it be best to just dump out the old gas and put in some fresh?
Oddball78
And also, how the heck do I set that Rich/Lean knob in the middle? I think my nephew screwed around with it and I'm not sure if its set right. I'm really not even sure what it does, or how to use it correctly.
Chinewalker
Was there any evidence of water in the fuel when you pulled the plug out of the carb bowl? These days, water in the fuel seems to be the most common issue I run into in my shop - probably half the motors that come in that ran well, then didn't, have water in the carb. Easy enough to check for - it'll bead up on whatever surface you dump it out onto.
Oddball78
Drained the fuel, replaced it with fresh and it starts right up. Looks like some water got in the line last rainfall. Thank you all for the help, I feel like an idiot lol
Rook66
When you started the motor up to check it did you do it with the lower unit in water?
