Hey guys, so got a quick question: When I tried to go fishing on Saturday, I got my boat to the dock and went to put her in reverse, but nothing happened...usually the engine will "jolt" because it is being kicked into gear, but this time it didn't do that. I tried going into forward and still nothing happened. So I took her home and looked at the prop real quick, and it spins freely while the motor is off. I tried putting it into reverse and the prop started to slowly move, I gave it a little gas and it seemed to spin like it would in idle (but I have it on the gas right now giving the engine some more rpms). I do the same for forward, but it doesn't seem to go as quickly as reverse does. While in forward and reverse, the prop doesn't spin at all, and I can turn it by hand but it won't get into gear.
I already changed the oil today and still the issue exists. I am using SuperTech Marine SAE 80W-90 Lower unit gear lube (GL-5) as the manual says to use GL-5 lube. Any ideas what the issue might be?
