1972 Evinrude 65 HP backfires, but won't start
blufire42
Just to clear the air, I am new to owning a boat, this is my first. Evinrude model 65273S.
Initially I bought the motor from a guy (he started it up for me before I bought it) and he told me that the motor ran, but the top coil wasn't working. He had replaced the coils and traced it back to the stator. I took the boat out on the water after making sure it would run once I was home and it seemed to work ok, just wouldn't accelerate above half-throttle even if I opened it up all the way. So I pulled the flywheel and looked at the stator, it had some brown goo coming off of it a little, so I bought a new aftermarket one and installed it.
Then the motor wouldn't start at all. I looked at the spark plug, not getting a spark, replaced it, still not working. I looked at the top coil and no juice, replaced it and still not working, I looked at the power pack and no juice going to top coil connection, replaced the power pack this morning and all I get is a backfire from the engine when I turn it over.
I think the battery was getting worn down from all my testing, so I am charging that while I am at work.
Any ideas as for why it is only backfiring and not starting? Could I have damaged something when pulling the flywheel?
Chinewalker
Miswired pack will do it, too. Backfires typically occur when the motor is out of time. If the pack wiring is firing #1 when #3 is supposed to fire, you'll get backfire, etc. Double check your wiring and report back...
blufire42
I put the new power pack in the same way the original was wired, but I did order a repair manual, I am just waiting for it in the mail. I'll double check the wiring when it comes in. Thanks!
boobie
You don't have to pull the flywheel to check the key. Take out # 1 spark plug, stick a screwdriver in the cylinder and rotate the motor until the piston is at top dead center. At that time check the TDC mark on the flywheel and the motor to make sure they line up. If not the flywheel key could be sheared.
