Total Basshole
Thread starter- Joined
- Jul 16, 2012
- 14
I am a new poster here trying to learn my engine. I recently got 1972 Evinrude 18 that has been sitting unused in the water for a few years (on a man made lake in the desert). I have been working to get her running smoothly. On the lower unit I noticed the washers on the drain plugs were leaking oil. I pulled off the lower plug, and from what I can tell from research, the oil should not have drained out until I pulled the top plug. The oil did drain out of the bottom hole, but the bigger issue was that when the oil started draining with the top plug still in, I had the water drain hole on the lower unit spit out some water mixed with black crap. I am wondering if this means the upper seals in the lower unit need to be replaced? I am guessing the air that leaked in that allowed the oil to drain was being pulled in from the upper seal and that somehow it released that oily water.
If I do have to pull the lower unit and replace the seals, can anyone give me some guidance on what problems I am going to run into? I am hearing that I cant remove the shift rod without taking the reverse gear off completly. I dont want to get into something I cant get myself out of.
Thanks in advance,
Thanks in advance,
