1972 evinrude 125hp won't idle
Corymit
I have a72 evinrude 125 and I can't get it to idle a few months ago me and my son were out fishing got to our hunnyhole killed the motor and that where my problems started could not get it started after that got a tow back got home thinking it was the primer bulb replaced it and it would start but I tried to ge it to idle it would spit spuder and die thing I've done changed plugs, rebuild carbs, cleaned cap and rotor. Check compensation 110 on all four, check reeds look great, plug wires look good fresh gas I'm out of ideas hoping someone can help me
Corymit
I don't know. I don't have a tester if it don't what would the solution be? I've taken the flywheel off and check the cap an rotor and the look great it has a pretty new pulse pack on it it's a cdi not the stock one
boobie
Do a cylinder drop test on it at idle and find the bad cyl/cyls.
Honorary Supreme Mariner
Run at night and look for sparks jumping to the flywheel from plug wires.
Corymit
Can the spark plug wires be removed from the cap I tried pulling on them but I didn't want to break anything. I've had the flywheel off and looked at the cap an rotor and they both looked real nice no white powder on it at all
Plug wires have an end crimped on.----They screw into the cap.
Corymit
What spark plugs should I use? I bought new ones and they were L76V is that the correct plug?
I sure appreciate the time your taking to help me out thank you
boobie
You could have a carbon track in the distributor cap. Look closely. Correct way to check out a cap is with a coil tester.
Corymit
I noticed the plug wires have a metal core can I replace them with regular automotive wires? And just replace the screw in terminal
Checked the fuel pump diaphragm ?-----Have you run it at night ??
Corymit
Ok I've came to the conclusion that it's a spark issue I've cleaned the wires put a meter to them their ok cap looks pretty good no cracks rotor looks good. High idle great spark 1/2" spark low idle week spark maybe 1/4" could it be the coil or what I'm about to loose my mind it's got me totally stumped
oldboat1
Maybe: choke linkage and operation (plate tightly closing for start up). Battery and starter condition (cranking rpms), along with wiring and connections. Fuel pump screen and diaphragm. Low idle setting (probably 1000 rpms on muffs, 750 in the lake).
Corymit
Ok found the problem it was the ground wires to the pulse pack it's running great now thank for all the advice and info thank you
