1972 Chrysler 203HD Temperature Question
3rdMarDiv
First post here on iBoats...:eek:
Finishing up a fairly thurough restore and cannot find temperature ranges for this motor...:grumpy:
Hoping to find operating ranges for low idle temp, running temp, pre-overheat temp, overheating (warning) temp...:confused:
My motor has no thermostat (that I know of)...:fear:
Any help here would be greatly appreciated...:pray2:
jerryjerry05
Re: 1972 Chrysler 203HD Temperature Question
Welcome. Guessing it's a 20hp.
Running temp should be around 130d overheat at about 160-170.
Pics?
3rdMarDiv
Pics?
Thank you for your reply...:happy:
Yes, it's a 20hp.
I have a non-contact lazar thermometer and I shut the motor down at 160. I will, in the future, stop it at 145.
I have been working on this motor for some time and ran 1st barrell test yesterday. Fixed, replaced, repaired, gear housing, impeller, fuel pump, carb, fuel lines, stator.
I have a twin to this motor (202HG) and it does not get too hot even at WOT. At idle I can press my hand on the heads.
Are you basing the temps you listed from experience or do you have specs?
From my reading your are correct as a thremostat should open at 145 degrees to cool the engine. 163 degrees is the low end of damage and should set of a temp alarm (if one is installed).
I do not have a thermostat and it pumps water well and continuously.
Any sugestions as to things I can check to determine why it's getting hot. Shows no signs of this happening in the past and it has good compression...:confused:
I am pretty fast at uploading pics...let me know what you would to see and I will snap and post...:rolleyes:
Barrell Test 07-18-2013
http://www.youtube.com/watch?v=PP9AEpYMq4g&feature=youtu.be
Thanks for your help, Gary
3rdMarDiv
I was able to determine that I was running the engine to slow in the barrell...:mad:
Turns out I needed to increase RPM's to increase impeller speed...:lol:
That increased wather flow and reduced engine temp...:faint2:
Now running as Jerry suggested at around 130 degrees...:drum:
Took it out on the lake this morning and now have another issue, which, I will post as another thread.
Thanks for the info...:clap2:
