As a newby, I removed the lower and replaced the water pump.
The shift lever has been changed and the lower unit spline has been turned by stupidity.
there are two plastic parts that slide onto the shift spline shaft in the lower unit and I dont have a clue as to the position needed to align with the female spline in the upper unit.
Help Help
Help Help
