1972 9.5 Which spark Plug
cottagebound
I have read numerous post that say to use different size spark plugs
Book says champion J4C
Champion site says J8C
when I bought the motor it had J6C in it.
Can anyone tell me which is the best to run in this motor. Also should the gap be .030.
Thanks
Vic.S
Re: 1972 9.5 Which spark Plug
J4C gapped at 0.030"
J6C are just slightly hotter.
The original gap was probably 0.040" but 0.030" is the current recommendation.
cottagebound
It may be a stupid question
what does running a hotter plug like the j6c do
shaffer
It just might burn a hole in a piston.Stick with j4c if you can find them.
Vic.S
using a very much hotter plug could well cause damage but the difference between J4C and J6c is not great. Sometimes the experienced folk on here suggest J6C rather than J4C for some engines
Vic.S
I believe they suggest it for certain models that are inclined to foul their plugs.
TN-25
A cooler plug means that the plug itself can transfer more heat away from the plug into the cylinder head (and the water jacket). A cooler plug can prevent pre-ignition when running at or near wide open throttle. Under those conditions combustion is hot enough to burn away deposits.
A hotter plug retains more heat on the plug. It is desireable if you do a lot of trolling since the hotter plug will burn away the deposits that accumulate when putting along, thus preventing plug fouling.
Running too hot a plug can result in pre-ignition, a situation where combustion happens too soon due to high heat in the chamber (it fires like a diesel). Combustion that happens too soon is very destructive to pistons & rods. It can scorch or even melt pistons, or break the ring lands off pistons, trashing the pistons, cylinders; in short the entire powerhead.
I'm trying to remember, but I seem to recall that a smaller insulater on the plug will alow the plug to throw heat into the surrounding water jackets to be carried away. A bigger insulator will inhibit the transfer of heat away from the plug.
kbait
J4.. J6.. It won't matter. We're not talking space shuttle tolerences here. If it's tuned close, they'll both work fine, and you'd never notice a difference.
