turtle1173
Thread starter- Joined
- Nov 29, 2001
- 437
Hi all,<br /><br /> I'm helping a friend of mine with his "new" motor. The model # is: 857HD<br /><br /> It has no spark and I want to test to see if it is a distributor problem or the CD module. My problem is that I don't have a wiring harness and ignition switch yet. The test I'm familiar with involves putting a spark tester in the coil, grounding it, and then grounding the wire on the distributor. I believe this test calls for the key switch to be turned "on."<br /><br /> Is there any way to do a test without having a wiring harness and key switch?<br /><br />Thanks,<br /><br />Shane
