turtle1173
Thread starter- Joined
- Nov 29, 2001
- 437
Hi all,<br /><br /> I've been having a problem with the motor not going very fast, even with the throttle wide open (on the controls and at the tower shaft). This particular incident happened Monday. I noticed when I squeezed the fuel bulb, it was slow to fill up again. It started up however and acted fine anyway. At WOT, it takes literally 2-3 minutes to get up on plane. Even then it is not planing right. My buddy thought my prop was pitched too high.<br /><br /> After fishing, I could only go half throttle. Any more and it would start to die. At the ramp I got to messing with it and when I turned the idle mixture screw on the bottom cylinder, it had no effect. So we all concluded that it needed a good cleaning. I checked the spark and the compression, both were good.<br /><br /> I found that the bottom carb did not have a nozzle. I don't know what exactly a nozzle does but I took the carb off my 55HP and put it on this one. It is a little different on the inside but it is still a Tillotsin WB (like the others on the 85HP).<br /><br /> I took it out this evening and after I ran it at the ramp for a bit, it died. I had a terrible time getting it started again. Finally it did. It shifted fine and everything, so I went out. I could only go at a fast idle (in gear). IF I tried to go any faster, it would start to sputter.<br /><br /> Back at the ramp, it looks like all the plugs are burning. How should I proceed??<br /><br /> The line from the tank to the fuel pump is a couple years old. I checked the screen at the pump and it was fine. I replaced the fuel pump a couple months ago. If I disconnect the fuel line at the fuel pump can I check the bulb by siphoning gas into a container or is that an inadequate test? If it's a leak could it be anywhere in the fuel lines?<br /><br /> Thanks for reading my long post but I like to be thorough.<br /><br />Shane
