1972 65HP Johnson low RPM's in gear
awakeatground0
Hi all, my 1972 65hp johnson outboard is having issues in gear. While under load the motor wont go above 2500 - 3000 rpms. In neutral i can easily get the rpms higher. It has done this before, and sometimes didnt do it at all. before, i was able to put take it out of gear, rev the motor a little, and put it back in gear and then off it would go. today, i tried that and nothin, it was a slow ride out and a slow ride back.
things that ive checked is the carbs, ive cleaned them and checked the floats. I checked to make sure the throttle cable was good, the carbs are opened all the way at WOT.
I read a post on here and everyone said it was the Power Pack(coil).
I was wondering if it could be an issue with the fuel pump.
Any ideas? I appreciate it
orbanp
boobie
Re: 1972 65HP Johnson low RPM's in gear
Sounds like it's not running on all three cyl's . Do a cyl drop test on it.
