awakeatground0
Thread starter- Joined
- Jun 5, 2013
- 21
When i purchased my boat, the guy i bought it from told me that the boat would not go into neutral by using the lever from the control box. He told me there was a pin in the control box that had broke. What he did, was wire a toggle switch to use to put the motor in neutral or forward. this switch works very well and has not failed me. I start the motor with the toggle switch in neutral and when its warmed up and im ready to take off, i throw the toggle switch into forward. now, reverse works fine from the lever on the control box, in and out of gear fine, but you have to make sure you are in neutral with the toggle switch. anyways, i want to get rid of this switch and ive been looking at parts for the control box to replace, however, i have no idea what pin he is talking about, and was curious if anyone has had this problem and could help. for all i know the guy i bought the boat from doesnt know what he is talking about, i dont know. could it be the drive shaft pin?????? any help is appreciated, thanks!
