MadCityMike
Thread starter- Joined
- Jun 9, 2007
- 12
I have a 1972 65hp Evinrude hydroelectric shift that starts fairly easy and seems to run good other then when trying to transition between idle and load. It always wants to die whether warmed up or not. If I flick the choke switch real quick and then try to give it gas I can get it to accelerate. if in neutral I can rev the motor just fine, but in gear it wants to die unless I flick that choke switch real quick. My understanding is that these carbs have no accelerator pump, but it acts like it needs more fuel when transitioning from idle under load so any hints on what might be the possible culprits? Thanks.
Mike
Mike
