Hi all - I got some carb rebuild kits and proceeded to replace needles, gaskets etc. On the low-speed needle, there's a part # 0314166 (Bearing Needle Valve, a small round plastic piece) that has split, so I went to replace it with the equivalent part in the kit. The one that came out is a softer plastic, the replacement one is a hard white plastic that I can't get in the orifice without putting pressure on the needle valve and I'm scared to force it into the screw hole in case I need to and can't remove it ... does anyone have any experience with doing this?
Thanks from sunny New Zealand!
