1972 65 HP Johnson rings: request advice
eric wood
I have new rings to install in acceptable bores (3 ring sets for the 3 cylinders, each set has a top or compression ring, and a lower ring, which I am not sure what it does or is called). To measure the ring gaps, I inserted the COMPRESSION ring into each bore, concentric and centered by pushing in with a loose piston, and take the gap at the top, 1" down and 2 1/2" down into the bore (the stroke is about 2 1/2"). I then read a compression ring end gap for all 3 cylinders that stays within tolerance (above) from top to bottom of the bore. When I repeat this reading using the LOWER ring, the gap is excessive from top to bottom, all 3 new LOWER rings, for all 3 cylinders.
It appears that the lower piston ring is supposed to have a larger gap than the compression ring, by about 0.005". OR.... I have the incorrect lower rings?
On 4 stroke motors there is a compression ring.-----And oil control rings.--------Your motor is a 2 stroke with piston rings !!-----Just put it together with the parts you have.-------It will run like new. !!
What are the gaps on the old rings ?--------And have you inspected the ring grooves in the pistons ?--------Putting new rings in worn grooves is not the best technique either.
F_R
Actually, in your motor, both rings are "compression rings". But if my memory is correct, the upper one is a "pressure back" ring. Wear in the pressure back ring groove is a bit more difficult to determine, since side clearance is hard to measure. But you can examine it closely for wear, carbon deposits, etc. Side clearance for the lower ring is .0015 to .0045. End gap is .007 to .017. for both rings. So, are you saying your gap is .017 + .005 (.022)? That's quite a bit, but it probably will run like that. On the other hand, putting it together with improper fits is counter productive, right?
