I've acquired a 1972 65 hp Evinrude with elecric shift. Motor starts and runs great. I understand the default process with the solenoids but when I start this motor in Neutral position it starts in forward gear. When I shift to Reverse position it goes to neutral. When I changed gearcase oil it was dark and contaminated with water and made me question what oil the previous owner used. I refilled with "C" type oil and problem continued. I have checked voltage at knife blade connections to solenoids and voltage is correct with corresponding button pushed. I have checked Ohms to solenoids and both wires check within 6 to 7 ohm window. When I use a jumper wire I can hear the solenoids click in the gearcase. When I shift from Reverse back to Neutral on control box the prop will stay in neutral sometimes and then times momentarily then go back to forward gear. I changed oil again this afternoon and the "C" type oil I had put in looked to still be contaminated but not bad. I filled with Dextron III automatic transmission fliud to clean out real good but made no difference in shifting. I am fixing to tear down gearcase to replace seals and any input anyone could give me on the shift problem would greatly be appreciated.
