1972 50hp model 50273c water pump question?
rnfor.jesus
Hey guys just purchased a 1972 50hp model 50273c. After some minor electrical repairs I got it running very quickly. I used muffs and wonder where I would see the water pump output? With the muffs water comes out of 3 holes at the top of the lower end. With the motor running I get water out of some vents midway up the lower end and out the prop. Should there be another spot? thanks, Brian
tashasdaddy
Re: 1972 50hp model 50273c water pump question?
that's it. you do know that is a hydro-electric shift. requiring special controller.
Hydro Electric Shift)
(J. Reeves)
The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.
You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Premium Blend" lube, commonly called "Type C". (A thinner lube)
In neutral, you need 12v to the "Green" wire.
In reverse, you need 12v to both wires, the "Green" one and the "Blue" one.
In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear)
To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed.
This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).
With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
larky
there are two holes on the back of the mid-section. just below the powerhead. those are the exhuast relief holes for starting and idling. they will also "spit" a little water at idle once the engine is warmed up and the t-stat has opened.
tevans720
Exactly!!!
Just went through the same stuff on my 73 50hp
