lovecat131
Thread starter- Joined
- Nov 25, 2011
- 11
My 50 hp has no spark in either cylinder. The clymer manual i have has a 72 65hp 3 cylinder so i am trying to follow the trouble shoot from that but it calls for special neon testers that i don't have. I have removed the black and yellow wire and that didn't work. Installed a new oem ignition switch so that shouldn't be the problem. I disconnected the brown coil wires on the left side of the power pack and i have 23 volts peak on both. Is 23 volts sufficient? Not sure where to look next. Hope you all can help.
