1972 50hp evinrude plug looks unused, new
phatmanmike
just bought this motor and have been running and testing and such. replaced plugs took apart and cleaned carbs. motor has no fire in #2cyl, plug is unused, #1 looks good, you can see burned gass and signs of fire, but #2 looks brand new, just wet. compression is 160# both cyclinders. i know i have fuel cause with plugs out, if i spin motor with starter fuel shoots out the plug holes, way out , like a spray. i hooked up a timing light to both plug wires and the light is good on both. is it possible that the boot on number 2 wire is bad and not allowing spark ALL THE WAY to plug? the wire is all taped up like it had been cut or sumthing... any ideas<br /><br />thanks always<br /><br />mike in florida, where its always boat weather :) :cool:
G DANE
Re: 1972 50hp evinrude plug looks unused, new
I think you have a leaking headgasket. If you have water in cylinder, plug will look brand new, even if cylinder fires. Carbon will get steam cleaned. Look if piston top is clean too. If it is you will have water in that cylinder.
G DANE
I didnt read your post fully at first.<br /><br />I would rig some kind of spark tester to both plug wires and let spark jump 5/8 or 1/2" to a good ground. If it can, spark is ok. Water can get into cylinder from exhaust jacket leak too, as some of the mixture actually will leave cylinder into exhaust and back again while it inhales mixture.
rickdb1boat
Could be the wire has an internal break or partial break. Nevertheless, it needs to be repaired. If the plug is wet with fuel, I would look hard at that wire as being the culprit. If it's steam cleaned, follow G DANE's advice. Take the tape off and see what it looks like and it there are any obvious breaks in it. Try spark testing right out of the boot.
phatmanmike
upon reading gdane's advice, i tokk off head and head cover, both gaskets are absolutly crap. water came out when i took off the cover, and then again when i took off head. both pistons looked good, walls look good. both pistons have small dime size clean spot where spark plug fires. there is a small 1/8"size hole in piston number 2, more like a round dent.. see attached pics, ...
<br /><br />cylinder number 2 is the one one the left, of the cylinder head pic....
<br /><br />is this normal. i cleand both pistons and head/block surface with wire wheel. iver never seen a outboard piston before.. any suggestions?<br /><br />mike
G DANE
Clean both surfaces real good. Dont use the wire wheel, it can roughn surfaces, I use a wood chisel with care in a sharp angle. Clean ( with petroleum ), dry and lubricate cylinder walls with 2stroke oil, to prevent rust. Check head for warpage, by holding a steel ruler at it at the middle. If it is warped, it can be straightened by sanding it on 150 paper taped to a glass plate, moving cylinder head in 8 figure movements. You can see when it is OK. If you feel unsure about doing this, take it to a machine shop and get it corrected. I dont think the very small piston damage means anything, and with the compression you had, rings and walls must be very fine. <br />You will probably end up having a great motor. I´d recommend OMC head gaskets only. Apply a little extra sealer on both outher surfaces, not around cylinders.
AlBarrs1
Mike;<br /><br />If one plug is firing and the other not try reversing the Ignition Coils to see if a coil may be bad. <br /><br />I have the same problem with a 1980 Johnson 35hp. It is getting strong fire on the top cylinder (1/2" gap) but NO spark on the bottom cylinder. I have just started troubleshooting after rebuilding the starter and cleaning the carb. Good luck Al
phatmanmike
heres the deal so far... took off and cleand head and head cover, got new gaskets for both. reinstalled both. still same problem. im getting a clean plug on the bottom. im getting fuel, im getting spark, installed new coils on both cylinders and wires and boots. <br /><br />im also getting a small trickle of water on the starboard side of motor where the motor attaches to the leg, just next to the exhaust ports.<br /><br />im getting a bunch of whitish/brown milky exhaust colored water coming out the prop. motor is misfiring bad. it runs the same on top cylinder alone as it does on both. although on occasion motor does run good, but you can hear when its on one cyl and when its on two.<br /><br />my manual doesnt tell me jack about the water jacket. i think GDANE hit the nail on the head. water must be getting into cyl number 2. what route does it take, where does it go and HOW CAN IT GET INTO THE CYLINDER......?<br /><br />EDIT: is the water jacket and the head cover the same thing? i am getting a lil bit of water coming from the head cover bolts, could it be warped. GDANE told me to use sealer, but i read that if you use sealer, it will corode the aluminum? WHAT KIND OF SEALER SHOULD I USE?<br /><br />any help is good help<br /><br />mike
G DANE
Hi again Mike - a bit of time difference between us - had to get some sleep. Looking at your picture of the cylinderhead I see what could look like a small crack beside the sparkplug thread on your bad cylinder. Is this just the photo or is there a crack ?? It shouldnt be leaking anywhere - now you have a looper and I dont remember how the exhaust side looks. However I have a 1988 40 standing in my garage, will take a look at it later today. Exhaust water jacket cools the exhaust at the side of motor, where exhaust leaves cylinders to mid section.
