1972 50 HP water pump
JonnyB
How do I know if my motor is getting enough water through the impeller? I am afraid that since it is an old motor the impellor might not work properly or might go out. How likley is this on the older evinrudes? It has always done good before, I guess I like prevenitive maintenance. Also it has an ajustment on the front of the motor for rich/lean fuel mixture but there is nothing on the inside, never has been since I had the motor. Is there somewhere I can get the little whatever it is that fits in there? Any help would be appreciated.
JB
Re: 1972 50 HP water pump
Routine PM on any outboard includes a new impeller each 2 years, Jonny. Many do it annually.<br /><br />If you plan to work on your engine, get a Service Manual.<br /><br />You can buy OEM Manual reprints from kencook.com, or you can get an aftermarket manual here: http://www.boatmotors.com/manuals.html <br /><br />Good luck. :)
rwcreigh1
i agree with jb.you also can get a cheap one on ebay.i like the seloc brand.i also replace my pump every 2 years
ddaigle
I dont believe that motor has a pee hole,(small stream of water out of side of motor to indicate if water pump is pumping) so a water pressure guage would be a good investment. My 70 model doesnt have a pee hole and the guage has been a lifesaver.
Marauderk
My 73 50 hp has a pee hose that comes off the top of the head in the rear. and i also have that knob up front connected to nothing at all lol been that way for as long as had the motor to
papasage
it should have a buzzar when it gits hot or a light . there is 1 tan wires that go into the left top side of the motor [standing behind it] . yoy can short it nd it will sound if working . a pee hose can be added if you want it . would put a pump in if you dont know haw long it has ben sinse it was replaced . i have run the 5 years with no probablem . guess luckey . most recomend every 2 years .
