1972 25hp Evinrude Shift lever replacement
1Dollar
I need to remove a broken shift lever from a 1972 25 hp Evinrude Sportster. I already have the replacement in hand. I just am looking for some guidance on how to get to the lever to remove it. It looks like the whole powerhead needs to come off? Can anybody shed some light on this process?
Thank You
hardwater fisherman
When looking at the parts breakdown for your motor, it looks like there is one screw going through the shift handle. And one screw under the handle that clamps it to the shaft. If you remove those two screws it should pop off.
Powerhead needs to come off.---Just nuts and bolts work.----Straight forward with no surprises waiting.
hardwater fisherman
I guess I read the question wrong. I thought he was removing the shift lever and not the entire shaft. Because I have changed a broken shift lever by just pulling it off the shaft.
1Dollar
Popped the powerhead off and replacement went with no issues. 1st time outboard boater but not too different from other engines I've worked on!
Thanks
