Kendegreat
Thread starter- Joined
- Mar 29, 2008
- 10
Hello,
I bought two Chrysler 70 HP motors, one is a 1972 and one is a 1973. Both supposedly run... However I using parts from one to fix the other. Anyway, 70 HP Model 707 HE is running and I replaced the Impeller. How ever after just a couple of minutes the overheat horn sounds. No water is coming out of the hole like it suppose to. It did at one time. I replaced the impeller with another new one... same thing. I was thinking maybe the Thermostat is not working and is closed. The SELOC manual says that there is four bolts holding the cover on. I can't find it. However I do see where one might be.... but I would have to take off the cover over the cylinders to get to it. Is the thormostat right above the Number 1 plug? Any suggestion on what I can do? Where can I find Gaskets and a thermostat?
Thanks,
Ken-De-Overheated
Thanks,
Ken-De-Overheated
