1972 18 hp evinrude flywheel pt number
Avoncrrc450
I've recently bought a 1972 18 hp eng model number 18202 , upon removal of flywheel I've noticed it is incorrect part number . The pt number is 581060 . Does anyone know what motor this flywheel is off? It has been ground down on the bottom side apparently to work on this engine. I'm currently lookin for pt number 581062 wich is the correct flywheel,can anybody shed any light as to what it's from?
rolmops
It is the part number for electric start flywheels of the 18, 20 and 25 horse Evinrudes. The other number for these flywheels is 581062
gm280
:welcome: to iboats Avon, great to have you aboard...
I have to ask a few questions. Was this engine actually working, running before you removed the flywheel? And if so what caused you to remove the present flywheel? Doing a cursory search, it seems EBay has one for sell for about $105 dollars delivered. And it is the same part number that fits the 20HP model as well. So do a little part number search, but with the word "flywheel" added to the part number to weed out other products that have the same part number. I did another cursory search on your old part number and it seems to fit a 1972 Evinrude magneto setup. You could sell it and help on the cost of your part number flywheel. And I would certainly upgrade the points and coils and condensers while the flywheel is off if they look suspect. Better now then having to remove it later on down the road to service those parts. Hope that helps a little...
Avoncrrc450
Bought motor not running , that's exactly what I was in middle of doing when I noticed bottom of flywheel was ground down apparently by grinder , looked up pt number for 18 hp n realized the wrong flywheel was on it. Could not isolate that number on web really not best w computers but can twist a wrench w best of me. Ps bought motor durin a snow storm has 120 n 115 psi so goin thru motor now
Avoncrrc450
