Past rebuilder has replaced #1,3 piston. #4 now needs replacement.Using telescoping gauges and vernier calipers Measring several times, I get bore diameter of 3.515, and a piston diameter of 3.476. Is this the standard piton385272 into a 15 thow overbore? All pistons new and old are the same diameter and the bores seem to be round and the same diameter, top to bottom. All bores will need honing and #4 has some damage from broken ring and broken piston in the ring groove area. This one may need an overbore but I haven't tried honing yet. I need to know whether these pistons are the standard size and what the piston diameter should be relative to the bore diameter . right now I have a difference of about .019
