1971 Starcraft Mariner 18-foot
Status
Not open for further replies.
BWR1953
Always good to get the ol' motor derigged and set aside! :eagerness:
No-AH
That's a big job out of the way....sweet looking stand! When I took the '90 off the holi, I ready'ed it on a shipping crate and strapped it down for the new owner.
steve_latino
No Title
Well...the evinrude is gone, turns out I knew someone who wanted a project! 👍🏻 Stripped all the old styrofoam out of the boat today and cleaned up the inside. Have a bunch of old pop rivets that I have to get out that were holding in the floor and then get a pressure washer to clean out the boat really well. Things are coming along nicely. Did have a minor oops pulling the old steering unit from the transom but it's repairable so I am not going to lose any sleep over that one. Things are starting to look good!
Watermann
There's always something unfortunate that happens when your doing the tear down. :lol:
I see your 71 doesn't have the hull stiffener braces under the ribs. Look it over very carefully for any rib end cracks. My Chief only had a few small cracks from the rivets. The stiffeners were placed in later SCs to overcome 2 potential issues that were design flaws. One being the rib end cracks and the other is the side spray rail chine splitting out. You're going to be out in the sea with this one, I would think about adding some stiffeners.
steve_latino
Watermann, thanks for the heads up. Man that CT thread is a doozy. Any advice on the stiffners. I know you talked about setting them in 5200...what types of rivets are you using to install them? Are they solid rivets. Assuming that would be a two man job? Unfortunately I haven't done much work like this before so any advice is welcome!
Old Irving
Good progress Steve. Tearing apart the boat is the easy part. Have fun with the build out.
Watermann
Yeah I didn't really do a tutorial or how to on the stiffeners like I could've. Solid rivets and 5200 on the stiffeners and the rib end crack patches. I was lucky that there wasn't any hull splitting like some and I have to mention the repairs that Grandad did on his Holiday. Bondo told the story of a spray rail chine splitting out while on the water on an older SC so it was stuck in my head to make the hull stiffener upgrades.
I added the stiffeners in between the ribs to eliminate the side spray rail failure issue but I believe it will also limit the flexing at the rib ends. It was a short cut so I wouldn't have to drill out rivets and lift each rib end that aren't factory bent to allow for it on the older SCs.
Just so we're on the same page the hull stiffeners are the braces that go from the bottom to the sides in between each of the ribs.
My current project SS has them factory installed under the rib end with about half as many ribs as the older boats like your Mariner and my Chief.
Watermann
First thing is to find any rib end cracks with a close inspection of the area well cleaned. If found the cracks need to be repaired properly. You have to look very close on the outside of the hull, the small cracks are tough to see and will only grow if left.
This is what I mentioned in the last post as being lucky on my rib end cracks. Anything like this has to be repaired, remove the rivet, stop drill the ends of the crack with a small drill bit, create a patch, butter it with 5200 and set patch with solid rivets. The patch on the outside will spread the stress and back the single layer of AL that's been fatigued.
Status
