bktheking
- Jul 29, 2008
- 5,057
Re: 1971 Merc 110 (9.8 hp) won't hit a lick!!!!
Not sure what you mean "carb isn't sucking fuel from the bowl". The carb doesn't suck the fuel, the reeds/piston movement causes that. Couple of things with these carbs:
1-Pull the cover on the top, underneath is a screen, check to make sure it isn't plugged. Be careful reassembling not to overtighten the bolt.
2-The float height (it isn't the traditional bowl type setup) has to be spot on, I have instructions how to check it for proper height if you need it. Set one way it won't allow fuel in, set another and it will shoot fuel out the relief hole, they can be tricky to get spot on.
3. There is an air orifice tube in top of the carb, they can get small particles in them throwing off the mix, they won't idle to save their lives if they are dirty. Unscrew it and make sure it's crystal clean.
4. Pull the bottom screw to reveal the jet, make sure it's clean.
Now on these carbs, going from memory, screwing in the idle screw richens the mixture, out leans- opposite to johnnyrude (someone else should confirm this, all memory at this point)
