MWatts9728
Thread starter- Joined
- Sep 17, 2010
- 10
I got a problem that seems a little mysterious to me. I bought the boat 3 years ago knowing it needed work but I needed a cheap fishing boat for a inshore fix. It?s a 1973 crestliner 17? Buccaneer with a 1971 Johnson 85ESL71A 85 horsepower outboard. The motor runs great and can fish all day on as long as both batteries are charged and we head back in after we run down the first. But I?m sick of heading back early. I replaced the old rectifier after seeing AC voltage months ago. Even though I?m getting DC voltage now it?s just running off the batteries. So today I pulled the stator out and bench tested it. According to the manual it works just fine. Tester with infinite resistance between the yellow wire against the metal frame on low ohm scale. Then tested 0.6 ohms between the yellow wire against the yellow with a gray stripe wire on a high ohm scale. I think the rectifier tested okay as well with resistance on each wire in one direction against ground and infinite resistance in the opposite direction. Double checked the wiring against a wiring schematic all the yellow wires meeting on the 1[SUP]st[/SUP] and 2[SUP]nd[/SUP] lugs with a metal jumper tying them together on the distribution block. And all the yellow/gray stripe wires meet on the 3[SUP]rd[/SUP] and 4[SUP]th[/SUP] lugs with a separate metal strap. And the red wiring from the rectifier meets only one other red wire on lug number five I believe. The diode and lead assembly has a green with a purple strip I believe the meets another wire of the same color the the 10[SUP]th[/SUP] lug. We tested that diode the in the same as the rectifier using the green/purple stripe wire as ground. And it showed some continuity in one direction on both wires but none in the opposite direction. I figure its time to ask for help before I start throwing parts.
As I see it there are two likely possibilities that remain: first is one of both The clipper assembly (A voltage regulator I think) is bad. And/or the diode & lead assembly is bad. As this lead doesn?t truly have a ground it can?t be tested in the same manner. But I believe this diode has more to do with the electric shift function as it ultimately ties to the remote for the drive. Do you have any other ideas? Is there something we could have done differently? Is there any way of testing the clipper assembly? And is clipper assembly just a fancy name for a voltage regulator?
