Jconnell43
Thread starter- Joined
- Sep 4, 2005
- 85
Got my 50 running fine in the tub at idle till the oheat alarm goes off after 2 minutes.
Not sure if it's an impeller or thermostat or pressure relief valve
Is it an impeller check to pull thermostat and cover and see if water exits the hole?
Tstat change is relatively easy compared to impeller change
Should there be a strong stream or a dribble?
If it doesn't I guess I need a new water pump kit.
Thanks,this forum is great!
