1971 johnson 50 No gas to carbs
Jconnell43
I can't get my Johnny 50 running in my tub, plugs seem dry.
The primer bulb is hard without squeezing, I just unscrewed the 2 bowl screws and nothing came out.
When I disco the fuel line from the engine and pump the bulb I get plenty of gas.
Shouldn't there be gas coming out of the fuel bowls when I pull the two drain screws.
Where else to look?
Many thanks,
Jim
Joe Reeves
I can't get my Johnny 50 running in my tub, plugs seem dry. The primer bulb is hard without squeezing, I just unscrewed the 2 bowl screws and nothing came out. When I disco the fuel line from the engine and pump the bulb I get plenty of gas. Shouldn't there be gas coming out of the fuel bowls when I pull the two drain screws. Where else to look? Many thanks, Jim
Yep... Gas ought to be pouring out of there! Either you have the primer bulb hooked up backwards (check the direction of the arrow on the bulb)... OR... the carburetor float needle valves are fouled/jammed solid and the carburetors need cleaning/rebuilding.
Jconnell43
Have cleaned the carbs,needles are clean and floats are at correct height.
I'm working my way backwards and I have fuel in but not out of the fuel pump.
I'm currently taking apart fuel pump looking for blockages.
Jconnell43
My bad, hooked up hoses wrong, now have gas to carbs.
