Caleb Teague
Thread starter- Joined
- Sep 15, 2019
- 1
Electric start. This motor sat for 3 years before I got it. I poured a teaspoon of oil into the cylinders before starting it, and cleaned the carb (no rebuild). Compression is at least even between cylinders and is fairly strong, moderately ifficult to pull the cord. But she fires up every single time. The engine works excellently at full throttle but idle is shaky and not right. The low speed passageways in the carb are well clear and cleaned. The adjustment screw is adjusted, any more clockwise and she sneezes. I've read the engine is probably sucking air from somewhere else and the upper crankcase seal is likely the culprit.
Is there a way to definitely test this? Also, when replacing this, do I need any special tools or knowledge for the timing system?
Thank you for any input you can give. It is greatly appreciated.
